No not yet, kit is ordered and I am planning the modifications from the first build. Here is a link to the first build.
http://www.rcuniverse.com/forum/kit-...short-kit.htmlone of the things I will do different is the way I build the wing, on chippy 1.0 I cut the ailerons and flaps free from the foam core wing, installed hinge blocks and the facings on the TE and LE, then glued the skin to the wing.
This time I will only prep the servo bays and the landing gear bays then sheet the wing.
I will add the blocks and facing once I cut the ailerons and flaps from the wing.
TB
