Originally Posted by
scottkieper
it is a 3 cell and when i put it on the charger it will not let me charge as it said voltage to high and read 14volts it will not charge or dis charge and there is no amps in the battery [will not run anything and when i take both lead and touch them there is not spark.
Your comments here do not make any sense; if there were any voltage (you say it reads 14 volts) and you touched the leads together you would definitely get a spark and possibly ruin the battery if it were good to start with. You can NOT have a voltage and then get no current flow if you join the leads-- an impossibility. I'd suggest you go to your nearest hobby shop with your battery and charger and ask for their advice or help as you do not seem to really know what you are doing.
