It should not be a problem but make sure you keep the ECU with the turbine. So since its a G all the valves are on the turbine and stay with it. You asked about the valves and if they are matched to the ECU. They are just open and closed valves and any valve will work with any ECU.
The only problem I could see is if the fuel systems are allot different and one has more suction then the other you might get a starting problem. But it would have to be a pretty big difference to hurt anything.
