Thank you CP
They made two versions in this class the CL Race and RC Race both have a long exhaust timing and need pipes to run right.
I do have the specs on the CL:
Exhaust - 182 deg.
Transfer - 130 "
Intake - 178 "
Stroke is 10 mm
CS .061 (1.0 cm³)
Manufactured in 1994
Another engine «Made in China» but probably not suited for the everyday user. This is a really hot racing engine for small control line speed models. It is intended to be mounted on an aluminum speed pan and to drive a single bladed carbon fiber propeller. Due to the long exhaust timing, the engine relies on the nice tuned pipe to run properly.
[TABLE]
[TR]
[TD="align: right"]Bore
Stroke
Displacement
[/TD]
[TD="align: left"]11.25 mm
10.00 mm
0.994 cm[SUP]3[/SUP]
[/TD]
[TD="align: right"]Exhaust
Transfer
Intake
[/TD]
[TD="align: left"]~ 182°
~130°
~ 176°
[/TD]
[TD]The transfer ports are slightly asymmetric causing the timing to vary by ca. 3° from left to right port.
[/TD]
[/TR]
[/TABLE]
