Originally Posted by
raptureboy
I have a Top Flite 60 size mustang, and when I drop the flaps to full it makes a diving left turn. even at 25% flap it turns slightly to the left. I have the flaps on seperate channels so they can be adjusted independently and have the control horns set in the same position. They appear to be in the same position when down or up. What could be the problem and possible solution?
Reduce the right flap travel a few notches. Just because they look even when deployed does not mean they are. This should correct your left turn problem.
