MVVS will answer questions very quickly if you contact them. Sending them an engine is very time consuming and fairly expensive. Chief aircraft will only service MVVS engines that they have sold. If you ever dismantle the engine to replace seals and bearings be advised the machine screw that secures the rod to the crank is a left hand thread. This machine screw requires a special socket. It took me two nights to machine one. Duncan James
