Mick,
Werner will not produce this type of gearbox. I do not know whether I's produce or not.
Overdrive at the oustside props: these props are not as deep in the water as the inside ones, they have less resistance. I thought I could use the same prop size as at the insiders if the revs are a bit higher...
