The engine box slides in or out to fit the engine you use. On my build I didn't build the engine box , bad idea, the box hold you fuel tank and servo for the engine. Once you sheet the fuselage nose area it is almost impossible to get into the tank or engine mounting bolts. If you want I can post some pictures how this is done.
Rich
