It's an (Electric) self rotating wing! Heli.
That is a New twist to an Old concept (Jet Tip) rotor blades.I have enlarged the Size of the Rotating wing 4ft. by 11 inches each Blade and they are turned by electric Motors with props.I am trying to promote it as a Unit that would use An E.V. as a Cockpit and Power supply!! The Larger wing Lifts More with less r.p.m.s and uses control surfaces instead of a tail rotor! On Jet Tip control surfsces are above rotor hub for axis.Mine is under But still works!!
Reason: forgot something
