And a morning clue. Thanks; Ernie P.
Question: What warbird do I describe?
Clues:
(1) It was the first of its kind for the country which built it; and the first to perform a feat which is, today, not only commonplace, but essential.
(2) It was also the first of its kind for a group of allies.
(3) It was recognized fairly early on that this aircraft would have a short lifespan; but it was put pressed into service to bridge a gap until newer and better aircraft could be readied for production.
(4) It began life when concern began to grow over new enemy aircraft being introduced.
(5) After conflict broke out, the aircraft began to prove its value in multiple roles; although continual problems with the engines, and other minor problems continued.
(6) At the same time, new technology breakthroughs allowed the aircraft to assume a new role; one previously reserved to other, larger aircraft. Its value in this new role was considered to be crucial.
(7) Enemy defenses in the conflict forced the aircraft into a night role. Despite the limited number of airframes available, its value was obvious.
(8) At the same time, the aircraft was made available to another friendly nation.
(9) During the same period, the aircraft began to prove its worth in its new role. Additional fuel tanks and another on-board aircraft system increased its capabilities.
(10) As the previous conflict wound down, and as other more capable aircraft began to be available, the aircraft was increasingly used in a reconnaissance role. In this role, its increased range resulted in new value to the aircraft.
(11) The aircraft’s new role extended its useful life. Still, by the late 1950’s, the aircraft no longer served a front line role.
(12) A few continued as test aircraft into the 1970’s.
