Depends on what you are powering it with, glow or gasoline or electric. If glow powered, make sure to use a paint that is fuel proof for alcohol and/or nitro methane, if gasoline you have a bit more choices as most paints will hold up under gasoline if left to dry/cure long enough. One of the better choices, although expensive, is KlassKote. That is an epoxy paint that is amazingly durable under all conditions and is easy to apply. You can either brush it on or spray it if you know the necessary info to spray.
Reason: Correct spelling of Klasscote
