RE: Profi 4000 Programming
What’s wrong with the standard method? In menu 1, servo, travel, you should have a default travel of 72%. Adjust the value to make the engine stop when trim is fully back, then on most engines you get the desired effect at mid and forward trim.
If you need more precision use a 7 or 9 point curve (I can’t remember which it is) because travel points 1, 2 and 3 correspond to the three trim positions when the stick is fully back and therefore the engine revs can be set precisely.
For a throttle kill switch go menu 1, control, throttle, fixed value, set to 0% and set the desired switch.
Harry
