Originally Posted by
jasonvo
Hi Henke,
I did checked my fuel line, it got no leakage or bubble air. My T35 idle at 96-98K and Pw 180-200, egt 590c - 600c (out door temp 35-37c).
My T35 setting: Pump start point 026, pump start ramp 013, I did changed pump start ramp setting up to 020 still the same).
My troubleshooting:
* Ran fuel pump with 6V - pump worked good. (fuel pump only)
* Ran without fuel filter and fuel valve results the same - no good (started up and idle till the tanks empty but couldn't pass 130k).
* Tried 3 types of fuel: diesel, kerosine and Jet A1 + 2% Jetcat oil. (gave me the same results start up and idle but flame out around 130K)
what else should I check? thanks
you can try increase acceleration to 035 or so, just to test. I think you might have a clogged injector, Pump value is a bit high which means the pump are working a little harder as it should.
*kinked line
*fuelfilter
*fuelvalve (electronic)
*clogged injector.
