Well, Balance day is here and it is tail heavy. Even with the 2 elevator servos removed from the back of the fuse. If I had to do it all over again, Id use the DLE-30. It could use the extra weight. I am using the DEVO 12S with Telemetry . I have up to 3 voltages, 4 temp, RPM, and GPS. all downloaded real time. Pretty cool. But I've never been able to look at it while flying. I took it out of my TF Cessna 182. it worked flawless in it.
