Old 09-12-2014, 06:55 PM
Saillfish
My Feedback: (17)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Rabbit V100 ECU problems
My V100 rabbit is getting a signal lost/incorrect message and if you menu down is says RX power fail. All batteries and connections have been check and tested with a volt meter. If I plug in a servo to the throttle channel it works fine. The HDT lights up with battery is connected to the ECU. Battery voltage is set right for a 2 cell lipo. All functions work, starter motor, fuel pump test, igniter test, gas valve, fuel valve etc. There is no pulse signal for the throttle on the screen. It just reads zero. The ecu shows the correct voltage on the screen. My ser. # is VT100-346. Please help. Thanks
Saillfish is offline
