(1) quality will directly affect the life is in a hot bearing vary widely, there are soaked in is low, the temperature crack, often bad, this is because.
Will two HuiHuo contributed to the vibrant, bad positive results. HuiHuo hypothermia, the harshest material, but it can be difficult to stress steel and any form of HuiHuo usually, bearing temperature of 150 ~ 180.
3. Life expectancy for thermal steps, in particular, if not the concentration of the
SKF Bearings or abnormal ideal, will increase a lot, the container of thimble carbonization and currently do not have bulk up very easily lead to the legitimacy of the potential of oil spills.
4. Life expectancy level, also forming bearing manufacture, heat treatment, if the forming temperature, too easily outbreak, form the most capable of heavy oil is uneven, a third of the containers of HFCS. Rolling remains reference to eliminate separation, the blacksmith PianXi, tantalum carbide, carbide often stay in touch, in order to solve the impact of air pollution.
Wholesale to repair the influence of carbide hot all organizational performance, is easy to be carburizing carbon and nitrogen at wholesale surface hydrofluorocarbons, if large GongXi GongXi, usually high carbon content, will more effectively strengthen rotation and carbon content is very high, because of the high hardness, and reduced life expectancy, fatigue failure.
Can be seen from the above situation, in many cases, this process in various professional and business HuiHuo four bearing life expectancy, decisive action to four steps need to be ready to control level, rather than simply monitor.
