RCU Forums - View Single Post - M4A3 Sherman Build
Thread
M4A3 Sherman Build
10-10-2014, 12:59 PM
11
manchu9inf
well, some progress was made on the turret this past week, the first pic has the parts i am going to use for the main gun. most of the metal parts are Heng Long parts and through test fitting them seem they will work well.
I had to modify the front of the tamiya turret by cutting off the extruding piece of plastic and add a little groove in each upper corner. I then glued the mantlet on and added milput to the inside to help hold the mantlet on and pushed it through the gaps on each end to seal it closed. I added the the smoke grenade launcher on the left side with a piece of brass tubing and then a small strip of miliput around that. Once that was done, i worked on adding the cast in extra armor on the right side cheek of the turret. Once again miliput came into play. i added a small strip of plastic at the bottom and miliput was added to represent the increased armor. I then painted the mantlet green and will continue to finish the trunion and install the main gun.
Reply
Like
manchu9inf
View Public Profile
Send a private message to manchu9inf
Find More Posts by manchu9inf
View iTrader Profile
