Old 10-15-2014, 03:40 PM
manchu9inf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
some work was done today, the idlers came back after getting a little work over from Daryl T. the original tamiya idler had the shaft cut off and a hole drilled through for the tamiya Tiger 1 axle that the idler will spin on. The Heng long idler had the brass bushing knocked out and two flanged bearings inserted for a smooth turn. lastly backing that up on the hull is another Daryl T part to keep it all tight. I will prime and mount the parts hopefully tomorrow night.
I also added the sand shield mounting brackets on to the hull. The picture i used as a reference. i was able to count 25 holes per side, i might be off by one or 2 holes, but it looks pretty good so far.
i also got Nick's rear deck mounted as well, this is a real nice piece. finally starting to look like a tank.
ID:	2040506   Click image for larger version
ID:	2040507   Click image for larger version
ID:	2040508   Click image for larger version
manchu9inf is offline
