Originally Posted by
littlecrankshaf
Thanks for enlightening me!
So what you are saying is the aircraft industry is lacking on making safer windshields and based on that you are against quad copters...and the FAA should essentially ground model airplanes with their ever expanding air grab...interesting logic.
No, I'm saying your ill informed sarcasm lends nothing to the discussion. I'm quite sure the aircraft industry can design a windscreen that is bird/drone/bullet proof but will it be light/affordable/or practical? I'm not saying the FAA should ground anything including quad copters however anyone flying anything directly in the approach path to an airport (subject of this thread) should be caught and punished.
http://www.airproxboard.org.uk/docs/...3%20-%20v2.pdf
Frank
