Originally Posted by
big_G
This picture shows the reason the wing failed. Insufficient support structure around the wing tube. It simply ripped the ribs right out of the wing. There should have been a spar box built around the wing tube, not in front of it. Simply poor engineering.
OTOH, why not build a foam wing for the model and toss the balsa wing? Yeah, it will set you back some green backs but will greatly reduce the possibility for a failed wing. Chances are good that the end result will be lighter than the balsa stick one. This model is inexpensive enough yet flies well enough as is to where an additional couple 100 won't kill the wallet.
