Results are in. I weighed the Spit and it weighs in at 33 lbs and 1ounce. That is ready to go except for ballast. After piling on 10 pounds of lead and still not achieving the correct CG I stopped to regroup. I am not sure if I can save this thing or not. I would like to know if anyone else has required this much ballast. Bird guy your Spit looks great and so does mine but the difference is yours flys and mine does not. Not sure where to go from here. Looks like I came in three pounds more than yours for some reason. I did a full cockpit with a full figure pilot but it looks like you did the same. I don't think I was heavy on the glue and epoxy but either way it is what it is. Any suggestions are welcome.
Spirfires Rule!!
