Tampaflyer:
My advice (if the fuel is fresh) would be to add 2.5% (1/2 quart) of turbine oil to the 5 gallons of fuel you have should you not be able to reach the individual who gave you the fuel with the jet.
All our turbines require 2.5% oil ration to fuel. Five (5) percent is overkill and going to 7.5% if you must, may cause injector atomizing issues and some popping as the only running issue.
As our friend Edgar suggested, dispose properly if you can. Have a friend with a diesel truck. . .he will I am sure welcome the opportunity.
Regards,
Eric Clapp
