Pull-pull setup
I am setting up my first pull-pull rudder control on a Yak 54 70" from ARF mfg. sold by General RC.
Based on my initial review it appears that the cable will rub on the slot that the cable goes through in the fuse. I am using the widest dual servo arm that fits into the fuse and am crossing the cables. I thought of lengthening the slots but there is structure just forward and just aft of the slot. I used a pc of rod to check the alignment and don't see any way around the problem.
I tried to get info through search tools using pull-pull setup without success. If you can send me to a forum that covers this I will appreciate it.
Any suggestions.
Gary
Reason: left out info
