going to the second side
Time to pop off the first side from the parting board.And get it ready to start the bottom.Start out by getting all the wax and clay off the what was in the parting board. To help me hold the 2 half's together before I put some bolts in,you see were I used a counter sink bit. When I do the other side if will make the counter part of them.
When it all cleaned up time to wax it 3 more times and buff it off every time.I also use some masking tape to cover the fiberglass from the first side,this so the second side will not stick to it.And so I do not get cut by it.
Time now to get the bolts ready to go in.This so when it is time to put the 2 half's together I can with 10/ 10/24 caps
