Could a Gas boar motor be used for a Drag Racing motor??
One of the differences i have noticed between a onroad gas motor compared to a boat gas motor the boat motor does not have a fan type flywheel. I suspect that the fan type flywheel causes drag on the motor that increases with rpm. I think that a boat motor can turn higher rpms than the same size onroad motor because it does not have a fan type flywheel. So my question is do any of you rc boat motor guru think I could get away with using a boat motor for a drag motor ??
