Originally Posted by
Dansy
Well mine should be on the way to me shortly.....something else to builds during the frigid winter.....debating between the K100 or the K80 same size probably the 100.... humm.
HV servo Futaba sbus and JR mini....with Jeti electronics and telemetry, should be fun
Daniel, I've flown the model with a VT 80, Rabbit and Rabbit SP. The 100N turbines will give you straight up climbs from takeoff. You will need a little throttle management during level flight as it will push the limit on speed.
Best of luck!
