Originally Posted by
M3Baker
Daniel, I've flown the model with a VT 80, Rabbit and Rabbit SP. The 100N turbines will give you straight up climbs from takeoff. You will need a little throttle management during level flight as it will push the limit on speed.
Best of luck!
Thanks, I'm a pattern flyer so throttle management is not a problems....I just don't know if a 80n will be enough for good vertical....been flying since the mid 80's but it's my first turbine plane, so I don't practical reference....
