Appreciate the replies guys!
Bird, Im too clumsy to use the dial so I'd better use the switch instead but thanks.
Carl, thank you...I actually replaced those triangular shaped connectors between the flaps with a wider piece due to my flaps would only drop a very small amount before they separated, I can get a good 90° out of those suckers now and they wont come apart if I needed too
