Originally Posted by
Rudeboy
I'm definitely not in a hurry.
I can live with a short kit, but would prefer a more complete pile of wood, since the plane is designed for imperial sized wood and thus I would have to special order a bunch of imperial sized wood to finish a short kit properly. Sanding down a trailing edge stock to fit is one thing, but sanding down a bunch of sheeting is another matter
What are your standard balsa thicknesses? The only remotely important dimension is sheeting thickness, and if you only had 2mm for example, then use that - perfect!
