RE: What could be the cause?
What does the MIRACLE WYE do? Reverse the servos? I'd bet this was causing the RX to act up, might be the RX's AGC function is stirring things up... The 24" extensions are more than likely not an issue. Are you using HD extensions, wyes and so on?
What version software revision is noted on the digital servos?
