The elevation arm i used. I made from the antenna bracket.
Hope that helps.
You will also notice that when assembled the turret will stick at 3 O clock. That is from the turret tabs that break easily. I created a 3 point frame from the runners and use a rubber band to gently pull the turret against the hull so the ring wont slip in the drive gear. This also helps in roll overs.
