Here is the new gear door mounted and connected to the main gear strut. The next step will be to put the "edging" around the cutout for the main wheel cover to seal that gap when the gear is retracted.
You can also see that there is a "chunk" missing from the corner of the main wheel cover that was apparent crash damage from the original owner that I'll need to fix...
Bob
