New From Tamiya!!!
TT-02R Chassis Kit
This refined, race-spec version of the TT-02 chassis features a wide range of option parts and newly-designed components to make it ready to race! The included racing spec parts include upgraded uprights, motor mount, shafts, joint cups and more, while the suspension is fitted with metal parts and CVA oil dampers. It retains the TT-02's versatility and easy-to-drive characteristics.
Featured components
Aluminum uprights (3 degree toe-in)
Aluminum motor mount
Included Hop-Up-Option parts
53159 4mm Aluminum Flange Lock Nut (Blue)
54247 3x18mm Aluminum Turnbuckle Shaft (Blue) x2
54501 TT-02 Aluminum Propeller Shaft
53642 5mmAluminum Ball Connector (Blue)
54500 TT-02 High-Speed Gear Set (68T)
54502 TT-02 Aluminum Propeller Joint
This is an assembly kit. Require assembling. Modeling Skill Required.
Require Radio Gears with Servo & ESC, Batteries, 540 Motor, Body
Toyota FJ Cruiser - CC01 Orange Painted Body
The Toyota FJ Cruiser is a retro style SUV with styling and off road performance reminiscent of the original Toyota FJ40 Land Cruisers. It was first introduced to the public as a concept car at the January 2003 North American International Auto Show. The FJ Cruiser was later approved for mass production after positive consumer response and it debuted at the 2005 North American International Auto Show in final production form.
The Tamiya R/C replica faithfully captures all of the full size FJ's details down to the large headlights positioned near the center of the front of the car, chunky fenders, and a trio of windscreen wipers. The FJ body is mounted on the capable CC-01 Cross Country chassis, which features independent front suspension and a rear 4-link rigid suspension set up for fun scale trail running enjoyment. This Limited Edition special release includes a pre-painted body, making it easier and quicker for the modeler to get his machine on the off-road trails.
Require Radio Gears with Servo & ESC, Batteries.
ESC NOT included.
Dark Impact White Ver. - DF03
This 1/10 scale 4WD buggy is specially designed to excel in off-road buggy driving fun. It features a mid-rear mounted motor and longitudinally mounted battery for optimum balance for jumping. The battery itself is inserted through the bottom of the chassis, eliminating the need to remove the body, which makes routine maintenance easy and quick. The high performance shaft drive 4WD is combined with a double wishbone suspension system featuring extra-long suspension arms for improved stability and off-road handling. This version of the Dark Impact comes molded in all white parts and is only available for a short limited time.
ESC NOT included.
Sponser Sticker Set - Off Road Car
This sheet includes a variety of stickers perfect for use on 4x4 off-road vehicles.
For more updates and specials please check us out on Facebook.
Banzai Hobby Team
