RCU Forums - View Single Post - Xicoy Electronic C.G. Balancer
Old 04-05-2015, 01:49 PM
  #56
olnico
olnico's Avatar
Originally Posted by FenderBean
I think this a great item for jets, since cg always seems to be a guessing game. Is it possible or will they be any defaults for people that can be selected in the unit? For example on something like the ARF kits all SM 1/6 f16 will have the same measurements and all the SM Bae hawks will have the same measurements. So just make a data base with these and make it were you just select the model and the scale and bam your done! Then over time as new models come out or different scales of a model you just release a new software update or even make it were u can manually enter and store it!
No, because some models have trailing link struts.
In that case the position of the wheel projected on the fuselage longitudinal axis will change with the weight of the aircraft.
One could say that 1 mm does not really matter, but this is not true in that case since the CG position is given to the mm...
