Hi Tom.
Well,I can see that you have put your "wood-working skills" to great use !!!! .............very nice "conversion-kit".............very well done.....just a bit too late for me to use..
I guess that you have "moved" the Saito nearer to the C/L of the mounting box.....correct..?,thus to allow for no cut out's required for the rocker covers...?..I assume also that you have retained the right off-set as std ..?
If not I guess that a bit of right trim will be needed to compensate for the C/L and off-set minus....?
Again,very nice job...............enjoy Toledo !!!
Cheers...................Nick (UK).
