I don't know what mine is but it would be easy enough to measure it as I leave the plane assembled and transport it that way. I find mine pushes to the bottom a little in knife and also tends to nose up a little when inverted. I suspect this one is a little tail heavy with only an OS 160 in it. It rolls beautifully, loops ok but not enough power for big loops. I like it a lot though but don't fly it often enough. I'll get out the incidence meter and check. It was used when I bought it and I never checked. I probably should. I might add that it is one of the nicest landing bipes I've tried and slows down more than I would have expected. It took me several tries to get used to it but is quite graceful on landing.
Rick H.
