The motor work well.
I repeated the 10S, throttle 100%test because thewire connection of the motor was bad and this failure caused a small EDF vibration .
WELLPOWER SE10S 5000mAh 30C
CHANGESUUN Ø 120mm 4 blades
CASLE PHOENIX EDGE HV 120
I used in this test:
-motor timing : low
-pwm rate : 8kHz
-power out : 100%
-static thrust : 39N
