Originally Posted by
fengjn
I have the Mini Avanti coming for my Wren 44. I will be pushing the engine as far forward as I can. The inlets do not look structural so I will be cutting the tops of them away. Can you confirm if they are structural? I will be using a 32oz dubro tank sideways with no header tank. I will be using a GBR filter clunk.
hello fengjin, after you have mounted tank and turbine, can you put a picture in this thread? i want to see your work, thanks
