RCU Forums - View Single Post - worst kit youve ever built
Old 06-20-2015, 04:14 PM
  #115
Chris Nicastro
Chris Nicastro's Avatar
CARF Eurofighter
Where shall we begin...
Asymmetrical - fuselage, wings, intake tubes
Mis-aligned canards - complete removal of factory installed parts and refabricated mounts and re-aligned canards
Wing thickness inconsistent for servo pockets
No bulkhead under the dorsal fin to transfer loads into fuselage
Air brake kit doesnt fit as purchased, needed extensive mods
Gear door set doesnt fit as purchased, needed mods
No provision for nose gear door air cylinder
Nose gear strut included with heavy duty retract set interferes with the door
One wing retract mount works OK to mount door to the wing, the other doesn't
Poor turbine motor mounts
Removed the rear bulkhead and redesigned a new one with more ventilation to relieve internal air pressure
And on and on...
Burned me out
