RCU Forums - View Single Post - Air-kill is coming back!
Old 06-23-2015, 07:18 AM
  #74
Airhead152
The Cores are for the original 1/12 scale designs. The P-51 is 37" I think. If you need to make the wing at 40" span and want to use these cores all you need to do is make a bigger balsa tip block to get the span you want or add a center section plug, or both. Not a big deal either way.
