What is the weight of your 4000mah batt? As per HK recommendation, I bought a 2800mah battery. Just curious how much weight I might need to add to use the 2800 batt. My Flying Balsa blades are finished but not covered. I hope these solve the shaking issue when spinning up the stock blades. Also, plan to reduce rotor tilt to 3 degrees left.
