Alfa Models Corsair, power configuration
I bought the Alfa ModelsCorsair way back when. I purchased an MP Jet AC 28/7-35 to put in it at the time. I don't know what the AC 28/7-35 refers to. Help please. The spec sheet shows model weight up to 17.6 oz. Model specs show finished weight at 14 to 16 oz. show should be good there. My next question is what battery packs to go with.(Li/PO). spec sheet says upto 3 cell.
Also, I have a Super Tigre brushless speed control w/Bec, 20 Amp. maximum). Motor spec sheet says,"short time current(A) 12". Current for maximum efficiency(A) to 8. If that means peak is 12 then I'm guessing the Super Tigre isn't what I want to use. Flown gas for years, just starting electrics. Any help appreciated.
Posted on beginners and got no response so thought I'd try here. Thanks
