Wing (cont)
Ailerons (cont)
Balsa block used for hardpoints in wing and ailerons.
Dubro heavy duty nylon hinges are used.
Slot for hinge is about an 1/8" from top surface and cut at about a 45 degree angle to get to the meat of the hardpoint and also puts the hinge pin at surface level.
Xacto saw blade used to make slot.
Due to curve of outer aileron, that hinge is moved inward.
Some easysand bondo to fill in gap between top sheet and LE.
