Today I finally got my turbine running correctly. The problem was a blocked injector(s). I stripped and dunked in kerosene and pulled suction with my tank filler pump. After about 6 minutes or so I heard a change in the way the pump sounded, I'm pretty sure that's when it pulled out the blockage. I reassembled and I could tell on the first start it was fixed. Parameters are now all nominal in the ecu and it runs good from low to high rpm. Wheew, I'm glad that's over.
