Okay, I finally got to post some pictures.
The first one shows the Pak when I was gluing the rear framing together.
The second shows the framing glued in up to the middle crossframe. The right sponson is also all glued to the sponson inside. The glued on rear bottom is also visible under the clamps.
The third and fourth show the sponson cross frames installed onto the sponson insides to my replacement 2000 Elam hull. I now need to get the lengthwise frames fitted and installed so that I can start adding skin.
I didn't take any shots of the Executone this time since I haven't done anything to it in several months
