Flybarless is easier to fly than flybarred. You go through the computer setup and follow the instructions system like ikon has self level so if you panic hit the switch and it levels itself. Flybar drift a lot and lot more parts to replace if you crash. I am fixing to try the ikon out wanting to learn more tricks so the panic switch sounds good. Blade has a 270 cfx that has this feature check it out. I already have 2 trex's so I am going with ikon for now. Good luck and there is lots of videos for set ups it's not that hard trust me.
