Problems with HELI-MAX AXE 2.4 ghz
I bought this helo new back in March. After only a month I was having problems when trying to hover. After hovering for a minute or so it would start spinning (left) out of control. I called Hobby services and explained my problem to them and they said it sounded like the e-board and sent me a new one. This worked good for a about a month or so and it started doing the same thing. They sent me another e-board and after installing it the same problem continued. So I called them again and this time I sent the helo to them to see if maybe they could find something I might have overlooked. They told me they checked out my helo and the only thing they could come up with was that they suspected the tail motor must be bad. They said this motor is no longer available but they offered me a trade in for another model helimax. I said no as I have a ton of spare parts for this one and it flies good when everything works right. Just send it back to me and I will get another motor which I did. This still hasn't solved my problem. So if there is anyone out there that may have some info to solve this problem I would appreciate hearing from you.
