Bought these APC pusher props, but they do not push the air. Tried putting them on each direction, with same results. Do I need to reverse the direction the motor turns ?
http://www3.towerhobbies.com/cgi-bin...?&I=LXPVF1&P=7
The original propeller "Pushes" the air in the right direction.
Also one more question. Can you take a regular tractor prop and put it on backwards to make a pusher out of it ?
Cary
