Got some wing sheeting done
The horizontal stabs and wings turned out OK.
I use water-base contact cement for the core to wing-skin adhesive. Apply the glue to the foam first because it takes a lot longer to become tacky. Once glue is applied to both surfaces and pretty much dry, carefully position the skin over the core and smooth down. Then back into the foam shucks (sp?) with much weight to keep things together and true.
Lots of tutorials on this all over the net with good variety in successful techniques.
W
