Originally Posted by
ZAGNUT
..................but only if you cut the unused part of the crank off. .......................
I do plan to cut the unused part of the crank off and blank off that end of the case. That formerly used for the clutch.
How do you suggest I do this? I don't want to press the big end bearing and pin out unless I absolutely have to. If I did, I would then have a problem chucking it in a lathe.
